Migrate a Phorum forum to Discourse
If you have an old Phorum forum and thinking to migrate to Discourse, then this tutorial is for you. The process is straightforward and we will be using the official Phorum Importer script. Let’s get started.
On a high level, we will do the following.
  • Preparing the local development environment.
  • Exporting the database from the production environment.
  • Importing the production database to a local Discourse instance.
  • Running the Phorum importer script.
What can be migrated
  • Categories
    • Every forums and folders => Root category
  • Topics & Posts
  • Users (with the following attributes)
    • banned status
    • username
    • real name => name
    • email
    • admin status
    • date added
    • last active
Preparing Local Development Environment
Follow one of these guides to install Discourse itself and consult this guide if you have any problems.
Install MySQL DB server;
Ubuntu 18.04:
$ sudo apt update
$ sudo apt install mysql-server -y
After finishing installing MySQL, check its status:
$ systemctl status mysql.service
If it is not running, run the following:
$ sudo systemctl start mysql
MacOS:
$ brew install mysql@5.7
$ echo 'export PATH="/usr/local/opt/mysql@5.7/bin:$PATH"' >> ~/.bash_profile
$ source ~/.bash_profile
Check the services status:
$ brew services list
You should see something like this:
mysql@5.7         started
Otherwise, run the following and check again:
$ brew services start mysql@5.7
For Windows, you can follow the official installation guide.
This environment will be our Discourse server.
Exporting The Database from Production Environment:
Export the production database (from Phorum production server):
$ mysqldump -u USER_NAME -p DATABASE_NAME > phorum_dump.sql
Copy the database dump to the Discourse server.
:bulb: Use scp or rsync to copy the database. And of course, you can gzip it first.
Importing The Production Database to Discourse server
On Discourse server, Create a database:
$ mysql -u root
:bulb: If your database user has a password you should use: mysql -u root -p then type your password.
mysql> CREATE DATABASE phorum;
Make sure that the database is created:
mysql> SHOW DATABASES;
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| phorum             |
| sys                |
5 rows in set (0.04 sec)
This is an empty database. Our next step is to import the production database into it.
$ mysql -u root phorum < phorum_dump.sql
While we are here, let’s get the table prefix. We will need it later:
$ mysql -u root
mysql> USE phorum;
mysql> SHOW TABLES;
You will see something like this:
| Tables_in_phorum          |
| pw_banlists           |
| pw_files              |
| pw_forum_group_xref   |
| pw_forums             |
| pw_groups             |
| pw_messages           |
| pw_messages_edittrack |
| pw_pm_buddies         |
| pw_pm_folders         |
| pw_pm_messages        |
| pw_pm_xref            |
| pw_search             |
| pw_settings           |
| pw_subscribers        |
| pw_user_custom_fields |
| pw_user_group_xref    |
| pw_user_newflags      |
| pw_user_permissions   |
| pw_users              |
19 rows in set (0.00 sec)
From the output above you can see that the prefix is pw_.
Running Phorum Importer Script
First, install the importer dependencies:
$ cd ~/discourse
$ echo "gem 'mysql2', require: false" >> Gemfile
$ bundle install
Now let’s configure the script to fits our requirements. In our example this will do:
PHORUM_DB = "phorum"
TABLE_PREFIX = "pw_"
BATCH_SIZE = 1000
host: "localhost",
username: "root",
password: "", # Change this if you have a password for MySQL database
database: PHORUM_DB
If you want to create a url redirecting, then you should uncomment the following:
# categories.each do |category|
#   Permalink.create(url: "list.php?#{category['id']}", category_id: category_id_from_imported_category_id(category['id'].to_i))
# end
# results.each do |post|
#   if post['parent_id'] == 0
#     topic = topic_lookup_from_imported_post_id(post['id'].to_i)
#     Permalink.create(url: "read.php?#{post['category_id']},#{post['id']}", topic_id: topic[:topic_id].to_i)
#   end
# end
It will be like this:
Run the importer with a clean Discourse instance:
bundle exec rake db:drop db:create db:migrate
bundle exec ruby script/import_scripts/phorum.rb
The importer will connect to the MySQL server and migrates our Phorum database to Discourse database.
Start Discourse server after the importer finish importing:
$ bundle exec rails server
Start Sidekiq to process the migrated data:
$ bundle exec sidekiq
:bulb: You can monitor sidekiq progress at http://localhost:3000/sidekiq/queues.
Setup your Discourse production server by following this tutorial.
Perform a backup for Discourse database and upload it to your Discourse production server by following this tutorial.
It’s done :tada:
I’m about to start work on migrating a Phorum forum to Discourse. I would like to preserve files attached to posts (mostly pictures). Looks like this is not supported in the current migration script. Has anyone noodled on that already?
I’ve made a couple tweaks to the migration script for “phorum” including migrating attachments/files/uploads. The pull request is here:
