Impossible to add new users
(Ruurd Eijzinga) #1
My settings are :smile:
invite only yes
login required yes
must approve users yes
enable local logins yes
allow new registrations yes
when I send an invitation to a new user and they click on the link in the mail they end up on the login page, but they don’t have credentials at this time.
So how do I add new users to my discourse ?
(Jeff Atwood) #2
Enable local logins and allow new registrations is the default. So you’ve changed
  • Invite Only
  • Login Required
  • Must Approve Users
@techapj can you check that combination locally? I don’t see anything incompatible there.
(Arpit Jalan) #3
Not happening for me. Are you on the latest Discourse version?
(Ruurd Eijzinga) #4
Hello Jeff,
Thanks for your answer
When I set it to the default I can create a new login /user
But we want to use it as a private blog
so therefor I set invite only, login required and must approve users
What are the settings for a private blog ?
Kindly regards,
Ruurd Eijzinga
