Improving color and contrast on topic progress widget
(Sam Saffron) #1
I find the contrast on and colors used for the topic progress widget to be extremely problematic.
  1. It does not mesh with the default theme - its an outlier color
  2. It has terrible contrast so its very hard to read for many
For my theme I ended switching colors to something I like many times more:
However, its not a trivial change, we need to make sure it works in all themes and uses some sort of function based on the themes colors
@awesomerobot is there anything we can do here to get a color that meshes better with good contrast?
Accessibility: Color contrast
(Jeff Atwood) #2
OK so @awesomerobot changed it to this
I agree the green was a bit much, and mapping it to “success” color made no sense. The motion of the bar as you progress in a topic is enough to make it visible without needing a special brighter color.
Also: less grey! yay.
#3
When tapping @awesomerobot and navigating to his user page. I’m not able to navigate back to this topic using the back button in my browser. I had to close the tab and find this post again.
Also: may I suggest something a bit more contrasty on the progress bar? Say white on black or white on dark blue or something like that?
Low contrast is a problem for people with color blindness (and otherwise )
(Jeff Atwood) #4
Hmm, no repro in Google chrome:
  1. Click @awesomerobot to expand user card
  2. Click his avatar on the user card
  3. Press back button
That took me back to this topic.
As for colors:
http://webaim.org/resources/contrastchecker/
Gives this a pass for large text, which it is…
#5
User card does not expand for me. I navigate directly to his user page. It’s repeatable for me. http://i.imgur.com/e1fIyma.jpg
Happens on this device and my nexus 7.
It seems to work in Firefox.
(Jeff Atwood) #6
Oh you are on mobile. Yeah that’s different.
