Inconsistent onebox rendering
(Christoph) #1
Am I missunderstanding something about how oneboxing works or why do some forum links render as a mini onebox and others as a full onebox:
Notify on every like should be the default
https://meta.discourse.org/t/change-timestamp-should-use-local-time-not-server-time/70552/3?u=tophee&source_topic_id=70788
And on an external discourse forum, these same urls render like this:
And on yet another external discourse forum, the first link doesn’t even produce a mini-onebox, it’s just rendered as an ordinary link…
What is the reason the source_topic_id that is added to internal oneboxes?
(Jeff Atwood) #2
Onebox is for external sites.
(Sam Saffron) #3
Mini onebox is currently restricted to internal links unless you change site settings, to be revisited in a month or so
(Christoph) #4
That is fine by me, but why does one internal link render as a mini onebox (or not at all if on a different discourse instance) and the other as an ordinary onebox?
(Sam Saffron) #5
Not following at all. You configure what you want expanded as mini oneboxes in site settings. Default is that you only expand internal links.
(David Taylor) #6
The reason the first link you posted rendered as a mini-onebox is that you put a space before it, so it was considered an “inline” link.
 https://meta.discourse.org/t/notify-on-every-like-should-be-the-default/40485?u=tophee
(Christoph) #7
Ooops. But I’m not sure that explains everything:
(Sam Saffron) #8
Well the second link is you trying to onebox a deleted post… so yeah … there is that …
(Christoph) #9
Okay, how about this one:
abc Discourse Meta
Is it intended that a private link is mini-oneboxed using the site title only (since the topic title is not available)?
