Independent ad option?
(Robert) #1
Hello everyone, I did search first
I see the ad options
and would like to use them like designed
But I need to keep it forum related (firearms) and have retailers ready take ad space
Is there a method to hang a banner of my own design between posts, categories etc?
Thanks.
(Erlend Sogge Heggen) #2
Are you using a particular ad provider or are you simply hand-crafting your own ads?
If the former, you should look at how new ad-providers such as CodeFund added an integration for their platform. If the latter, you might be better off making theme components for your custom ads.
(Robert) #3
Fantastic , I can likely use the footer for starters I would guess :thinking:
Yes, hand crafted
Perhaps then figure out how to put some between categories or something more attractive
Thank you for the tips :sunglasses:
(Mariano Rodriguez) #4
You could also use Google Ad Manager, previously Double Click.
It’s supported by the plugin and lets you manage your campaigns as you like.
(Robert) #5
I sincerely thank you for your help,
unfortunately their policy on our content is prohibitive,
again, I am grateful for your help.
Robert
