Inline onebox does not work on private topics
Here is some content of the first post of a topic:
Why is OneBox not working, giving a preview of that topic?
Some settings that can be causing the problem:
Is it a public topic in a public category? Should work, if so… checking enable inline onebox on all domains looks correct to me.
No, it’s a private topic in the same private category
Not gonna work on private topics my friend, they need to be externally visible.
Okey, then I’ll just edit the post once we make it public to generate the OneBox :sweat_smile:
@codinghorror It’s still not working, even on public categories :sweat_smile:
Just check the first link
Unless you can repro it here or on try.discourse.org, it’s something with the site’s config. Maybe you should rebake the post using the admin wrench if you changed the target from public to private, too.
I’ve already Rebuilt HTML, but nothing :confused:
You could try adding a random querystring to the URL if you think caching is an issue.
Already done, and it’s not :confounded:
It’s weird, because linking topics from a category to a different one works, but if topics are from the same category it doesn’t
