Instalations on subdomains
(Igor Da Cruz) #1
You can perform an installation of Discourse in different forums that have no relation between them subdomains?
For example:
games.domain.com
movies.domain.com
tech.domain.com
Therefore, each subdomain have its categories separately.
And another question, complicating the situation, you can have only one active login for both subdomains? Ie who log into games, you can also access and logged in to post all content in movies and tech.
Thank you for your help
(Sander Datema) #2
Search for multisite and you can have Discourse installed on subdomains. Have people login using Facebook, Twitter, etc. and it looks like they have just one account.
(Jeff Atwood) #3
Good points but remember cross-site messaging and notifications will be weak and/or nonexistent, when you use separate Discourse instances.
(Igor Da Cruz) #4
thanks, I had looked for something but did not know that the term used was “multisite”
(system) #5
(Jay Pfaffman) #6
You can do this. You can make one site the SSO master and the others sso clients so the share a single login. You can do this using a multisite instance or separate standalone sites.
(David Taylor) #7
