Install Discourse on Ubuntu for Development
Hi all
I’m new to developing on discourse and have been following this guide to setup a development environment for Discourse.
However, I am facing a nasty issue which I have been trying to solve for hours trying to find people with the same issue but to no avail.
When I ran the script linked in the guide to download the necessary technologies, it failed on downloading postgresql (cut for brevity):
Setting up postgresql-common (188.pgdg16.04+1) …
dpkg: error processing package postgresql-common (–configure):
subprocess installed post-installation script returned error exit status 10
dpkg: dependency problems prevent configuration of postgresql-10:
postgresql-10 depends on postgresql-common (>= 182~); however:
Package postgresql-common is not configured yet.
dpkg: error processing package postgresql-10 (–configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of postgresql:
postgresql depends on postgresql-10; however:
Package postgresql-10 is not configured yet.
I figured it might be a PostgreSQL issue on Ubuntu but it seemed like other people are facing other issues pertaining to their problem and I am having a different problem. Can anyone assist me?
I am using Ubuntu 16.04 Xenial. Thank you!
See Backup has failed. pg_dump: server version: 9.6.3; pg_dump version: 9.5.10 for instructions on installing postgres 9.5.
Hi
Thanks for the reply.
I followed the steps and got this now:
The following information may help to resolve the situation:
The following packages have unmet dependencies:
postgresql-9.5 : Depends: libgssapi-krb5-2 (>= 1.14+dfsg) but 1.13.2+dfsg-5ubuntu2 is to be installed
Recommends: postgresql-contrib-9.5 but it is not going to be installed
Recommends: sysstat but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Hi
Anyone available to help me with this issue?
Hi,
Are you trying to setup discourse dev environment for the first time ? Then this worked for me like a charm.
Hi
I tried this setup but I prefer to run the development environment in Linux as I use it more often :slight_smile:
Do you have any held packages?
Run dpkg --get-selections | grep hold to find out.
