Install on Virtualmin
(Kingofseo) #1
Hello,
Is it possible to install discourse and get it working on Virtualmin.
Thanks
(Régis Hanol) #2
I don’t know virtualmin, does it support Docker? (I highly doubt it) If not, then you can’t.
(Kingofseo) #3
I found this I just converted my site to Discourse! think it should work will give a try shortly.
(Wes Osborn) #4
Just a reminder that only installations using the methods outlined in the install instructions are officially supported:
(eriko) #5
Basically they are using virtualmin as a proxy in front of a normal looking docker install. This is pretty normal. We use a separate proxy/loadbalance in front of a number of apps to provide SSL without having to put our wildcard cert on a bunch of servers.
(Kingofseo) #6
Thanks.So it will work right ?
(eriko) #7
If you are doing what I think you are doing it should. I had some issues telling discourse to return https urls as my proxy server (Xen Balancer) did not send the correct header to tell discourse what to do. There is a hack somewhere to force discourse to do this.
