I have a server machine that is provided by a private vendor to the company. In this server, there is one website that is already operated using nginx, named as api.example.com. I tried all the suggestions here, I run "./launcher rebuild app --docker-args “–add-host extra.dns:8.8.8.8” command or this command "./launcher rebuild app --docker-args “–sysctl net.ipv6.conf.all.disable_ipv6=1 --sysctl net.ipv6.conf.default.disable_ipv6=1 --dns 1.0.0.1 --dns 1.1.1.1” or only “./launcher rebuild app”. But, for any case it didn’t work out everytime, it is the same problem, I got the following error.
**I, [2019-07-04T06:03:25.662572 #16] INFO -- : > cd /var/www/discourse && gem update bundler**
**ERROR: While executing gem ... (Gem::RemoteFetcher::UnknownHostError)**
** timed out (https://rubygems.org/specs.4.8.gz)**
**I, [2019-07-04T06:04:26.075400 #16] INFO -- : **
**I, [2019-07-04T06:04:26.075885 #16] INFO -- : Terminating async processes**
**I, [2019-07-04T06:04:26.076003 #16] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 70**
**I, [2019-07-04T06:04:26.076089 #16] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 186**
**2019-07-04 06:04:26.076 UTC [70] LOG: received fast shutdown request**
**186:signal-handler (1562220266) Received SIGTERM scheduling shutdown...**
**2019-07-04 06:04:26.092 UTC [70] LOG: aborting any active transactions**
**2019-07-04 06:04:26.094 UTC [70] LOG: worker process: logical replication launcher (PID 79) exited with exit code 1**
**2019-07-04 06:04:26.095 UTC [74] LOG: shutting down**
**186:M 04 Jul 2019 06:04:26.175 # User requested shutdown...**
**186:M 04 Jul 2019 06:04:26.175 * Saving the final RDB snapshot before exiting.**
**186:M 04 Jul 2019 06:04:26.205 * DB saved on disk**
**186:M 04 Jul 2019 06:04:26.205 # Redis is now ready to exit, bye bye...**
**2019-07-04 06:04:26.253 UTC [70] LOG: database system is shut down**
**FAILED**
**Pups::ExecError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 306 exit 1>**
**Location of failure: /pups/lib/pups/exec_command.rb:112:in `spawn'**
**exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "find $home ! -user discourse -exec chown discourse {} \\+"]}**
**2ccd64cc0a831137458be59bf4cf19f0ab6fa75b86ba891effb3a8f12b02ab89**
**** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one**
And, I checked with tcpdump -i docker0 -n port 53 command, it again stuck the connection that is realted with rubygems.org… Here is result of tcpdump:
08:53:54.478415 IP 1.0.0.1.53 > 172.17.0.8.52862: 3398 0/1/0 (115)
08:53:56.808205 IP 172.17.0.8.48960 > 1.0.0.1.53: 31050+ A? rubygems.org. (30)
08:53:56.808235 IP 172.17.0.8.48960 > 1.0.0.1.53: 7332+ AAAA? rubygems.org. (30)
08:53:56.809944 IP 1.0.0.1.53 > 172.17.0.8.48960: 7332 1/0/0 AAAA 2a04:4e42::70 (58)
08:53:56.854069 IP 1.0.0.1.53 > 172.17.0.8.48960: 31050 4/0/0 A 151.101.192.70, A 151.101.0.70, A 151.101.64.70, A 151.101.128.70 (94)
I couldn’t figure this out, prior to Discourse forum, the company got forum.example.com already operating with Docker, what would be the problem here? Did I mess somethings up or is there any connection problem.
Thanks in advance.
