Installation fails :( :( hoping for some help
i followed the installation guide to the letter,
jumped through some hoops to get to this point,
and now i’m stuck… :frowning:
please, i’d like some help with this…
rene@parakeet:~/data1/htdocs/said.by/discourse$ bundle exec rake db:create
rake aborted!
TypeError: superclass mismatch for class Command
/var/lib/gems/2.7.0/gems/thor-1.1.0/lib/thor/command.rb:2:in `<class:Thor>'
/var/lib/gems/2.7.0/gems/thor-1.1.0/lib/thor/command.rb:1:in `<main>'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/lib/gems/2.7.0/gems/zeitwerk-2.4.2/lib/zeitwerk/kernel.rb:34:in `require'
/var/lib/gems/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:332:in `block in require'
/var/lib/gems/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:299:in `load_dependency'
/var/lib/gems/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:332:in `require'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:53:in `require_relative'
/var/lib/gems/2.7.0/gems/thor-1.1.0/lib/thor/base.rb:1:in `<main>'
/var/lib/gems/2.7.0/gems/thor-1.1.0/lib/thor/group.rb:1:in `<main>'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/generators.rb:6:in `<main>'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/app_updater.rb:3:in `<main>'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/tasks/framework.rake:41:in `block (2 levels) in <main>'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/tasks/framework.rake:40:in `block in <main>'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/tasks/framework.rake:3:in `<main>'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:77:in `load'
/var/lib/gems/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:326:in `block in load'
/var/lib/gems/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:326:in `load'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/tasks.rb:18:in `block in <main>'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/tasks.rb:17:in `each'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/tasks.rb:17:in `<main>'
/var/lib/gems/2.7.0/gems/bootsnap-1.7.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:59:in `load'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/application.rb:522:in `run_tasks_blocks'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/engine.rb:464:in `load_tasks'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/railtie.rb:207:in `public_send'
/var/lib/gems/2.7.0/gems/railties-6.1.3.2/lib/rails/railtie.rb:207:in `method_missing'
/home/rene/data1/htdocs/said.by/discourse/Rakefile:9:in `<top (required)>'
/var/lib/gems/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
