Installation hiccup possibly due to recursive .profile call
(happycollision) #1
While installing Discourse using Digital Ocean and 12.04 Ubuntu (64) and following the steps outlined at https://github.com/discourse/discourse/blob/master/docs/INSTALL-ubuntu.md, I found that switching back to the ‘discourse’ user after installing missing components that rvm told me about would just hang.
So I finally checked out my .profile and here is what I found:
# ~/.profile: executed by the command interpreter for login shells.
# This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
# exists.
# see /usr/share/doc/bash/examples/startup-files for examples.
# the files are located in the bash-doc package.
# the default umask is set in /etc/profile; for setting the umask
# for ssh logins, install and configure the libpam-umask package.
#umask 022
# if running bash
if [ -n "$BASH_VERSION" ]; then
    # include .bashrc if it exists
    if [ -f "$HOME/.bashrc" ]; then
    . "$HOME/.bashrc"
    fi
fi
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
    PATH="$HOME/bin:$PATH"
fi
[[ -s "$HOME/.profile" ]] && source "$HOME/.profile" # Load the default .profile
[[ -s "$HOME/.rvm/scripts/rvm" ]] && source "$HOME/.rvm/scripts/rvm" # Load RVM into a shell session *as a function*
That second-to-last line of actual code seems to be calling this very file again, causing an infinite loop. I commented it out and was able to log in as ‘discourse’ successfully.
I have no idea if this is somehow just a problem for me, or if others might have a similar issue. Just wanted to let someone know.
(Michael - DiscourseHosting.com) #2
Yes, that seems like an error in the install guide. It was .bash_profile sourcing your .profile but these instructions make it recursive:
# rvm added shell initialization code to ~/.bash_profile,
# move it to ~/.profile instead
cat ~/.bash_profile >> ~/.profile
rm ~/.bash_profile
I think this bit could/should be deleted, not just because it creates a loop but it also throws away everything that used to be in .profile
@supermathie what was the reason for putting it like this?
(Kane York) #3
Actually, no, it doesn’t throw anything away from .profile, I think – shouldn’t >> be append?
(happycollision) #4
I believe that putting everything into .profile is because rvm won’t be loaded as a function unless .profile is read at login. And, if I am not mistaken, .profile is not read at login if .bash_profile exists.
So I see the necessity (in theory), but I am not familiar enough with bash to suggest a fix.
(Michael Brown) #5
When originally written, the rvm installer added the following line to ~/.bash_profile:
Nowadays, things have changed and the installer now adds:
So yes, the instructions now cause .profile to source itself. I was trying to make the install instructions as simple as possible but I made the assumption that the changes RVM made would be stable. I’m fixing that now:
(Michael Brown) #6
This topic was automatically closed after 24 hours. New replies are no longer allowed.
