Installation problem with voting plugin
#1
Hello
The plugin seems installed as I can see it under plugins as v 0.4 and about 9 different plugin settings available…
However when I edit category, while I see additional options from other settings I do not see the allow voting checkbox. Any help with troubleshooting would be most appreciated.
(Joshua Rosenfeld) #2
Is the plugin enabled? Search for voting enabled in site settings.
#3
yes. i unselected and the reselected to make sure. same result unfortunately
(Geoff Hutchison) #4
I’m seeing the same problem. I have the plugin installed, voting is enabled, but I don’t see the option when editing category settings.
(Sam Saffron) #5
Can you try reproducing the issue?
(Joshua Rosenfeld) #7
On try.discourse.org I see Allow users to vote on topics in this category in category settings. I’ll test this on a non-hosted site too, but it appears to be working.
Edit: It works on a non-hosted install as well.
(Geoff Hutchison) #8
Is there any possibility of voting conflicting with other installed plugins? I have solved installed, much like the OP.
My use case is that I have support and development categories. I’d like to use solved in the support category, and voting in the development category.
(Joshua Rosenfeld) #9
Anything is possible, but I find it very unlikely it’s conflicting with another official plugin. We run the voting plugin along with a large number of other plugins internally.
Can you share the full list of plugins you’re running?
(Geoff Hutchison) #10
This is what I’ve got right now - everything is up-to-date.
discourse-details 0.4
doi-resolver 0.6
MathJax support for Discourse 0.4.1
discourse-narrative-bot 0.0.1
discourse-nginx-performance-report 0.1
discourse-presence 1.0
discourse-solved 0.1
discourse-voting 0.4
docker_manager 0.1
lazyYT 1.0.1
poll
(Geoff Hutchison) #11
I’m happy to get further debugging information if there’s something else needed.
(Joshua Rosenfeld) #12
Can you confirm which MattJax plugin that is? What’s the Github repo?
(Geoff Hutchison) #13
It’s this one: GitHub - kasperpeulen/discourse-mathjax: Mathjax plugin for discourse
(Joshua Rosenfeld) #14
Ah ha! Yes, there’s a very high chance that plugin is causing interference. That plugin is quite out of date. Please switch to GitHub - discourse/discourse-math: Official MathJax support for Discourse. More details can be found in Discourse Math Plugin (see “What about the old plugin?”)
Please do me a favor and switch to the current math plugin and let me know if the issue still exists.
(Geoff Hutchison) #15
Yeah, that seems to fix my problem at least.
