Installation with database and web on different servers
#1
Forgive me for this really basic question but it seems that the Discourse installation is Docker based and includes everything including the database, but for production wouldn’t you want to separate the database from the web server on different machines? If so how would I do this? Thanks
#2
Kinda found an answer to my own question.
(Felix Freiberger) #3
Yes, that’s how you can do that.
But please note that for most installations, the default is fine. I’d recommend you get started using the standard instructions. If it later turns out that performance is getting poor, it’s easy to switch :slight_smile:
