Installing problem (Ubuntu 17.10)
When installing
> WARNING: We are about to start downloading the Discourse base image
> This process may take anywhere between a few minutes to an hour, depending on your network speed
> Please be patient
> Unable to find image 'discourse/base:2.0.20171231' locally
> 2.0.20171231: Pulling from discourse/base
> 50aff78429b1: Pulling fs layer
> f6d82e297bce: Pulling fs layer
> 275abb2c8a6f: Pulling fs layer
> 9f15a39356d6: Pulling fs layer
> fc0342a94c89: Pulling fs layer
> 35787b1294ac: Pulling fs layer
> 9f15a39356d6: Waiting
> fc0342a94c89: Waiting
> 35787b1294ac: Waiting
> 275abb2c8a6f: Download complete
> f6d82e297bce: Download complete
> 9f15a39356d6: Download complete
> fc0342a94c89: Download complete
I have a feeling you are just not waiting long enough… I don’t see anything described as a problem there.
Nothing has been going on for an hour
Where are you installing? Is this a production machine?
It’s probably unrelated, but it’s generally better to stick to the LTS versions for a server.
Ubuntu desktop 17.10
. . . reconfiguring . . .
Saving old file as app.yml.2018-02-13-161808.bak
cp: после 'containers/app.yml.2018-02-13-161808.bak' пропущен операнд, задающий целевой файл
По команде «cp --help» можно получить дополнительную информацию.
Stopping existing container in 5 seconds or Control-C to cancel.
Deployed with the installation, but after it localhost:
# Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to [nginx.org](http://nginx.org/).
Commercial support is available at [nginx.com](http://nginx.com/).
*Thank you for using nginx.*
Probably you installed external Nginx, that uses port 80 and blocks Discourse internal Nginx during deployment. What guide do you use to install?
DigitalOcean tutorial
You will need to either stop the host version of nginx or uninstall nginx from the host server. That way docker establishes the connection.
If you need a proxy (host to use nginx), there is a tutorial for that too in #howto
