Intermittent 404s for stylesheets on Heroku
(Stephen R Foster) #1
I just deployed Discourse to Heroku. When I refresh, the content renders without a stylesheet – sometimes. The output is identical to the issues reported in these threads:
I can reproduce the issue pretty consistently when I trigger a hard-refresh. However, after a few refreshes, the problem sometimes fixes itself.
When the content fails to load, the JavaScript console shows a 404 for:
/uploads/stylesheet-cache/desktop_b531a23882f83514263baf6c609f33fcc9f3dbfa.css
I’m not doing anything fancy with my installation. In fact, I have another Discourse installation on Heroku that works just fine.
Also, I just updated to the latest version of Discourse on Github. Yet the problem persists. Any help would be appreciated.
Thanks,
Stephen
Intermittent stylesheet errors on Heroku installation
(Jeff Atwood) #2
Is this a Docker install? We cannot support any other kind of install, sorry. Massive number of variables.
(Stephen R Foster) #3
It is a Heroku installation. Thanks anyway, though.
(Stephen R Foster) #4
I was able to make the problem go away by scaling the number of Heroku dynos down to 1. After digging through the code a bit, I’m guessing I was getting weird behavior due to the distributed cache and multiple processes.
I understand that Docker is the supported platform, but just for my own curiosity, can anyone tell me if Discourse is intended to only work with a single server process? Or is there a potential bug here?
–Stephen
(Jeff Atwood) #5
Hard to say, we focus on Docker to reduce the number of variables.
I will also note a Docker Discourse install at $10 per month on Digital Ocean is probably at least 5x to 10x cheaper than running Discourse on Heroku. Plus we could support it…
(Stephen R Foster) #6
Good to know. Thanks. The software is really incredible. I’ll definitely consider switching to Docker.
