Internal Server Error when trying to create a Shared Draft with tags
When trying to create a shared draft with tags from any category, the shared draft fails to create, with an Internal Server Error.
Shared drafts can be created without tags. Once created however, trying to add tags results in a “Sorry, an error has occured” message.
Once published, tags can be added to the topic.
@danielwaterworth can you have a look?
@udan11 can you add that to your list? Feel free to close this topic if it’s not reproducible anymore.
I successfully created shared drafts with tags. I was able to edit them and add or remove tags too. This bug no longer exists.
