Invisible Button Text + layout misalignment on Horizon Theme
Dashboard: Button text invisible by default + layout misalignment in “Top Referred Topics” & “Trending Search Terms”
Hi
I’m using the Horizon theme and have identified several UI issues in the Admin Dashboard, specifically in the Top Referred Topics and Trending Search Terms sections.
:magnifying_glass_tilted_left: Issue 1: Button text is invisible until hover
Location: Buttons in both sections (e.g., “View topic”, “See search term”)
Expected behavior: Button label should be visible at all times (normal state).
:straight_ruler: Issue 2: Column width imbalance & text wrapping
Observed layout:
Topic / Terms column: too narrow → long titles wrap vertically (e.g., multi-line text inside a single row).
Numeric columns (Views, Clicks, Searches, etc.): overly wide → excessive whitespace.
Additional issue: Numeric values are right-aligned (default for numbers), but in RTL contexts (like Persian/Arabic), this creates visual inconsistency. For better UX in RTL locales, numeric columns should remain right-aligned, but topic/terms columns must be left-aligned — currently they appear right-aligned in RTL, causing misalignment.
Thanks for your work on Horizon theme.
Thanks for these reports, will be fixed!
For next time though: some screenshots are very helpful to quicker identify what it’s about than text.
Are addressed in
https://github.com/discourse/discourse/pull/37845
For next time: please make separate reports for each issue.
I’m not tackling the RTL issue in this commit (this is also most likely not Horizon specific).
One of our upcoming projects is a rework of this entire reporting area so I’ll try to keep the RTL support in mind when working on it then.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
