Invite Users - Account Name and Password
(Ian Tornay) #1
Is there a way to make it so that sending an invite to a prospective user prompts them to select and usersname and password instead of automatically assigning these values?
(Jeff Atwood) #2
I believe if you use a CSV list of invites you can specify username. However, password is something the user has to set. “Knowing” the password, at any time, is a security violation and is not possible.
(Eli the Bearded) #3
I think the request is for invites to not provide any defaults for account name or password, instead only to ask the invitee for those.
(Ian Tornay) #4
This is correct. Sorry if I my initial request was not clear.
Current functionality:
User receives invite, accepts invite, is take straight to discourse forum, has been assigned a username and password, user does not know their password.
Desired functionality:
User receives invite, accepts invite, is taken to account creation interface where they select username and password
(Jeff Atwood) #5
We designed the invite system so people can get in and start posting immediately; nagging the user with a dialog isn’t in the cards at the moment. You should be able to specify username in the CSV file of invites, though.
(@techapj can you confirm this is the case with usernames and the CSV invite file?)
(Ian Tornay) #6
I can appreciate that.
But I think there’s always going to be a question in the back of a user’s mind – “What is my username? What is my password?”
And there’s the added disorientation of the user not being able to log back in because they don’t know their password.
I can see both sides. Having the option to prompt account creation would be nice, but it’s not critical.
(Jeff Atwood) #7
Your password is your email address, generally speaking. Guess what happens when you forget your password? :wink:
(Arpit Jalan) #8
Currently, specifying username is only supported when generating invite links via Discourse API. Here is the howto:
