InviteEmail broken
(Margrave) #1
Hello,
I’ve been a happy Discourse admin until 2 days ago, it stopped sending invites by email.
My gateway is mailgun, the configuration has not been touched and when I use the ‘Send test email’ feature within the forum I receive an email normally.
What fails is the job called InviteEmail, what can I do to properly troubleshoot this issue and make it work again?
The only thing I did recently (and I believe that’s the cause) is upgrade from 1.7.0 to 1.8.0 (both beta).
Thanks in advance for your help!
(Joshua Rosenfeld) #2
What are you seeing in your admin email section? Anything useful in skipped?
(Margrave) #3
Josh,
Not really, the last entry dates back from December 3rd…
From that same email section I can send test emails that work, so I believe it’s the plugin or job called InviteEmail that’s broken, where can I check this specific thing?
(Joshua Rosenfeld) #4
That I’m not sure, sorry! Someone else with more email familiarity should be able to give you a hand.
(Jeff Atwood) #5
Can you verify there are no issues with Emil invites @techapj?
(Arpit Jalan) #6
Just confirmed that Email invite is working fine here on meta and on try.
Can you PM me the complete error log? (Let me initiate a PM, you can reply there.)
