iOS: Keyboard hides topic field
(Larry Salibra) #1
Continuing the discussion from iOS Chrome - mobile form inputs are impossible to use/broken:
Having a similar problem in iOS 8 beta 4 on Safari - keyboard hides the topic body field. Makes it hard (impossible) to see what you’re typing. Not sure if this is a temporary beta-only problem that can be ignored or if it will be permanent behavior in iOS8. Thought I’d report it either way in case others run into the problem.
(Jeff Atwood) #2
Please do not report “bugs” on beta OSes and browsers here. We have a very strict policy about this.
If it is still a bug when the OS is released, by all means.
(Jeff Atwood) #3
