Is Discourse compatible with Google Blogger paltform?
(Alex) #1
Hi Guys,
As I am new to this forum sorry if its a silly question.
I have a blog hosted at google blogger which is really popular in the software and games known as Filesmag. But i did a little vote and asked many of my members if would they like a forum for the problems and errors in the software which the blog provides which they can use to discuss it on.
My question is that will I be able to work with discourse e.g. like forum.mysite .com and does it effect my SEO? Thank you
Sorry if i have posted anything wrong
Here is my blog if needed incase: Softwareabyss.net
Admin may delete if not appropriate :smile:
(Kane York) #2
I think you should be fine if you don’t want to replace the comments - don’t think that Blogger will let you do that. You will want to set the subdomain up with whoever you bought your domain name from.
(Alex) #3
hi thanks for helping
what do you mean by replacing the comments?
(Discourse.PRO) #4
Moreover, you can place Discourse forum to subdirectory like http://www.softwareabyss.net/forum
It would be better for SEO because the forum will inherit some of the SEO metrics of your existing site.
Technically, it can be implemented by Nginx (proxy_pass all request except /forum to Google Blogger).
(Alex) #5
Thanks for the help guys going to try this soon
