Is discourse working on ArchLinux now?
#1
Hi!
Is there anyone who tested Discourse on Archlinux nowadays? I just like ArchLinux. There is no unnecessary packages installed by default. So I want to install discourse on it. But I don’t want to reset my current system so I need to verify if it is working or not… Any idea?
(Jeff Atwood) #2
First port of call is, does Docker work on ArchLinux?
#3
As far as I know, yes it is. I can see docker package on archlinux repo and also I can see a page for archlinux in docker documentation.
(Jay Pfaffman) #4
It should work then. If you’re paranoid, you could install Archlinux on a USB drive without mucking up your hard drive.
#5
Yes it works. At least a few months ago when I set it up for testing on a ArchLinux VPS with 2GB of RAM. :wink:
