Is Gleam embed code supported?
Does Discourse supports hosting Gleam giveaways? Gleam provides HTML embed code, but I tried it in a Discourse post and I couldn’t get it to work/display.
The short answer is yes! Everything I see here can be done in a theme component. The amount of work required on your end depends on which method you want to use.
In theory it does yes, but when I put the HTML embed code into a topics post, the Gleam widget doesn’t load.
This is all I see, instead of the Gleam widget. It’s just standard embed HTML provided from Gleam too, which works fine on a WordPress site.
