Is it possible into discourse like yoast seo does in wordpress?
Currently If i can create new topic and want to add custom title and meta description for them.
is it possible into discourse like yoast seo does in wordpress?
Change the topic title to the title you wish it to be using the normal editing tools. Custom meta description per topic is not possible nor planned on any roadmap at this time.
If i change the title then it will change the URL also. If i change multiple URL then it will show 404 errors to all pages.
Is there similar thing possible like, I can change title but do no change the URL?
Like as below: (May be its called like “Custom Slug Feature”
Title - Is it possible into discourse like yoast seo does in wordpress?
URL - discourse-do-like-yoast-seo-does-in-wordpress
This is not correct. You can change the title as much as you want and the URL is still the same because of the numeric ID in the URL.
https://meta.discourse.org/t/is-it-possible-into-discourse-like-yoast-seo-does-in-wordpress/104979
also works as
https://meta.discourse.org/t/anything-goes-here/104979
