Is there a POST or GET /logout URL?
I am using Discourse as my SSO (and forum, of course).
I want to be able to allow logout from my main application, without requiring the user to go to the forum, click on their avatar and selecting the Logout option.
I traced the network and it seems to be an HTTP DELETE on that username:
Is there no other GET or POST way to call this?
I cannot issued a DELETE from a URL in my site (or as part of a 302 redirect).
I did look into the API method (https://meta.discourse.org/t/discourse-sso-logout/28509/4), but that seems to require installing a gem (I think) on my client application side for using the API key, and my client application is not using Ruby.
Try issuing a POST request to that URL, with a request body setting _method=delete. That probably still works as a hack around browsers not learning to HTTP.
Am I doing this right?
You can see _method=delete in the POST request.
It’s giving me a 403 back, and yes, I am logged in as “reverend_paco” in my own forum. Is this method/hack no longer supported?
Yeah, looks like it. Bummer.
just more information:
I’m doing this with a 307 redirect. I noticed there are no cookies being set on the request. Interesting.
If this is user side code - You are missing your csrf-token and user cookies
If this is executed by the server - You are missing api_username and api_key.
definitely user side… i just noticed the cookies were missing, don’t know why that would be with a redirect… maybe the 307 loses the cookies?
I don’t believe a redirect will work on it’s own - you would still need a CSRF token
… obviously work out why the cookies aren’t there first.
thanks, do i need a csrf if i am on the same domain but different sub-domain?
My main site is wordadoplicus.com (where i have a logout button and which is not forum related at all)… the forum is installed at the sub-domain forum.wordadoplicus.com.
With some minor exceptions my understanding is that all POST requests are required to pass a CSRF token regardless of their origin domain.
Hell, I could be wrong.
You could probably prove this in your browsers JavaScript console for the actual Discourse install…
… generate a POST request using jQuery / JavaScript.
EDIT: I can confirm that POST with data _method: delete works for /session/{username}
Note that I previously mentioned you could test this in your browser using jQuery post - however you then run into ‘Access-Control-Allow-Origin’ header is present on the requested resource when executing on the parent domain - so not a great way of testing.
However it did prove the request works locally.
@DeanMarkTaylor, thanks for all of this. Just to clarify, you confirmed that a POST worked with the CSRF token?
I appreciate everyone’s help here thus far.
thanks,
dainel
Only confirmed endpoint accepts the post request.
When I tried it the cookies and csrf included automatically because I had a session open and was using a debug console on the current domain.
You are probably looking at a situation where a browsers default security will prevent the cookies from being included because they are set on the sub-domain.
Oh goodness gracious. I just discovered that my assumptions about the server-side API were wrong. Thankfully, I can use the API, and will thus be abandoning this client-side attempt.
I had assumed that the Discourse API required the ruby gem because there was some sort of encryption going on. In fact, all you need is the api_key and username. I had assumed that it would be a security risk since people could sniff the api key and then use it later.
I can thus logout a user from my application by using pure web calls.
For those doing erlang, it’s as simple as:
  6 kick_em_out(User) ->
  5     Logout = [<<"https://forum.wordadoplicus.com/session/">>,
  4               User,
  3               <<"?api_key=6a28b548eee3dce8bedd56cd3ac8691dea34f5222ca6c5b5556cc257f2ed2c4e&api_username=">>,
  2               User],
  1     API = iolist_to_binary(Logout),
  0     httpc:request(delete,{binary_to_list(API),[]},[],[]).
Hence why TLS is such a good idea. No different to a session cookie, either.
Good to see some Erlang code again.
This is on 1.6 with many security exploits, I suggest either taking it down or updating it to latests?
