ISO-8859-1 error in static embedding
(Thomas Purchas) #1
I’m trying to integrate comment embedding from discourse into a website that produces ISO-8859-1 encoded HTML.
I’m pretty sure its all working, the IFrame appears and says loading comments, however the topic retrieval and parsing is currently throwing regex errors (Job exception: Wrapped Encoding::CompatibilityError: incompatible encoding regexp match (UTF-8 regexp with ISO-8859-1 string).
I can’t convert to UTF-8 (old PHP codebase), is there any way of adding ISO-8859-1 support, or re-encoding the retrieved pages into UTF-8 before attempting topic creation?
CompatibilityError: incompatible character encodings: ASCII-8BIT and UTF-8
(Mittineague) #2
iconv somehow?
http://php.net/manual/en/book.iconv.php
"Open links in new tab" does not work from Profile page without http
(Thomas Purchas) #3
That would seem like an obvious solution. But it’s difficult to change the charset in HTML, because it also changes what the browser sends back.
This means if I send out UTF-8, I need to make sure that I capture and convert anything sent back (form submissions etc).
The site I’m working on is old and written by students (student society website) so making sure that I convert everything sent back and handle it properly internally its quite a lot of work.
I’m looking at various options to convert to UTF-8 in the future because the current encoding scheme used causes headaches everywhere, but there is no simple solution :frowning:
(Kane York) #4
One hack would be to detect if the requester is Discourse, then add another ob_buffer (it does use a stack, right?) and convert the page to UTF-8 right before finishing output, as well as translating the request parameters to 8859.
