Issues bootstrapping due to encoding error
(Nilesh Patil) #1
Is this plugin working fine?
I’m getting BOOTSTRAP Error while installing this plugin.
I pasted
– git clone https://github.com/discourse/discourse-sitemap.git
in app.yml.
Other plugins are installing properly only getting error with this sitemap plugin.
Any solution?
Discourse Sitemap Plugin
(Sam Saffron) #2
What does the error say. Scroll up.
(Nilesh Patil) #3
/pups/lib/pups/cli.rb:15:in split': invalid byte sequence in US-ASCII (ArgumentError) from /pups/lib/pups/cli.rb:15:inrun’
from /pups/bin/pups:8:in `’
ea8fcc7c3335a445cba1cda814b01ad1b3027d16a29788e13c0899c7c4f9c056
(Sam Saffron) #4
Something is messed up in your app.yml file, you can try iconv to fix it or something like that.
No idea how you made this happen.
(Nilesh Patil) #5
But other plugins I installed successfully. Only getting the problem with the sitemap plugin.:worried:
(Sam Saffron) #6
You probably corrupted your text file when you pasted the line in.
