Javascript getElement methods doesn't work
(SMHassanAlavi) #1
Hello.
I want to find some element in my web page with id = “ember1124”, But my code doesn’t work.
for Example:
<tr id="ember1124" class="ember-view topic-list-item category-ورزشی" data-topic-id="27">
You all can see the id=“ember1124” but
document.getElementById(“ember1124”);
return nothing. or in some cases it returns wrong number with .length method.
I also used getElementsByClassName and methods like this but they don’t work in my case.
document.getElementsByTagName(“body”);
works fine but it didn’t work well for other tags
(Mittineague) #2
The ember#### id can’t be safely used (they change)
What I’ve found is that using querySelector works as long as the element can be targeted. eg. (untested)
... querySelector(div[class~="topic-list-item"]);
Or maybe the problem is where / when the JavaScript is being run. (compare view-source against your dev tools elements view)
(SMHassanAlavi) #3
I found the class full name in css and I want to usget elements by class name but I don’ t know how to convert this name.
the name is :
.topic-list a.title.visited:not(.badge-notification)
what is the real complete class name???
(Mittineague) #4
I can’t recall having ever seen this
Where on what page is it?
(Kane York) #5
I think they want to select the topic title on the topic lists.
(SMHassanAlavi) #6
Yes I want to select the title.But I can’t
(SMHassanAlavi) #7
Here it is:
I want to select the topic title but I don’t know how
(SMHassanAlavi) #8
what is query selector.You mean $(’#id’) ??
(SMHassanAlavi) #9
in the front page.in title table
(Rafael dos Santos Silva) #10
document.querySelectorAll(".topic-list .main-link a.title")
is working fine.
(SMHassanAlavi) #11
thanks but this code
var element = document.querySelectorAll(".topic-list .main-link a.title");
alert(element.length);
returns 0 but I have at least 5 topics
(Rafael dos Santos Silva) #12
Where exactly are you running this code?
Discourse is a Javascript app, so if you execute this code on page start, there is nothing to be seen.
You can read about creating Discourse plugins or about getting a simple callback when things are ready.
(SMHassanAlavi) #13
I use the code here:
I want to create a dynamic table for my site
(Rafael dos Santos Silva) #14
That will not work, as when querySelectorAll runs there is no site yet.
Read the links I posted above.
(SMHassanAlavi) #15
I wrote a plugin like this but it returns 0 again
(SMHassanAlavi) #16
Thank you. I got my answer
