Job exception: timeout expired
ّI have so many of these errors in my log. I don’t know what’s exactly the problem.
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/pg-0.21.0/lib/pg.rb:56:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/pg-0.21.0/lib/pg.rb:56:in `new'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/pg-0.21.0/lib/pg.rb:56:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:684:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:215:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `new'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `postgresql_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:809:in `new_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:853:in `checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:832:in `try_to_checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:793:in `acquire_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:521:in `checkout'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:380:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:1008:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:118:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:90:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/relation/delegation.rb:46:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/relation.rb:525:in `alias_tracker'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/association_scope.rb:26:in `scope'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/association_scope.rb:7:in `scope'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/association.rb:91:in `association_scope'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/association.rb:80:in `scope'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/collection_association.rb:288:in `scope'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/collection_proxy.rb:960:in `scope'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/associations/collection_proxy.rb:1130:in `where'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.2.0/lib/active_record/relation/finder_methods.rb:81:in `find_by'
/var/www/discourse/app/models/user.rb:558:in `visit_record_for'
/var/www/discourse/app/models/user.rb:562:in `update_visit_record!'
/var/www/discourse/app/models/user.rb:1230:in `update_previous_visit'
/var/www/discourse/app/models/user.rb:600:in `update_last_seen!'
/var/www/discourse/lib/auth/default_current_user_provider.rb:81:in `block in current_user'
/var/www/discourse/lib/scheduler/defer.rb:70:in `block in do_work'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-2.0.4/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/lib/scheduler/defer.rb:68:in `do_work'
/var/www/discourse/lib/scheduler/defer.rb:59:in `block (2 levels) in start_thread'
Can you please try a rebuild?
cd /var/discourse
./launcher rebuild app
rebuild didnt fix the problem.
this is also another error that frequently is reported:
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `new'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:684:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:215:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `new'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `postgresql_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:809:in `new_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:853:in `checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:832:in `try_to_checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:793:in `acquire_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:521:in `checkout'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:380:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:1008:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:118:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:90:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/app/models/topic_view_item.rb:22:in `add'
/var/www/discourse/app/controllers/topics_controller.rb:746:in `block in track_visit_to_topic'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/connection_management.rb:63:in `with_connection'
Hi, sorry for the necro-bump… but I see the same error related to background jobs:
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/pg-1.1.4/lib/pg.rb:56:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/pg-1.1.4/lib/pg.rb:56:in `new'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/pg-1.1.4/lib/pg.rb:56:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:692:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:223:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:48:in `new'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:48:in `postgresql_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:811:in `new_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:855:in `checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:834:in `try_to_checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:795:in `acquire_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:523:in `checkout'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:382:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:1014:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_handling.rb:118:in `retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_handling.rb:90:in `connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/model_schema.rb:466:in `load_schema!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/attributes.rb:234:in `load_schema!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/attribute_decorators.rb:51:in `load_schema!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/model_schema.rb:459:in `block in load_schema'
/usr/local/lib/ruby/2.6.0/monitor.rb:230:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/model_schema.rb:456:in `load_schema'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/model_schema.rb:346:in `attribute_types'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/attribute_methods.rb:230:in `has_attribute?'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/inheritance.rb:55:in `new'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/persistence.rb:52:in `create!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_scheduler-0.9.2/lib/mini_scheduler/manager.rb:73:in `process_queue'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_scheduler-0.9.2/lib/mini_scheduler/manager.rb:30:in `block in initialize'
I tried to rebuild the app several times with no luck. Any hint? Thanks!
EDIT: what I noticed is that there was a backup pg_dump stuck since days ago, I restarted the app, it went away but Sidekiq still seems not working.
EDIT2: I started the backup manually and I see pg stuck at the following query COPY public.email_logs (id, to_address, email_type, user_id, created_at, updated_at, post_id, bounce_key, bounced, message_id) TO stdout;. It can stay there for ever… probably that’s why Sidekiq cannot connect to the DB again and fails to retrieve new jobs…
More insights… it seems that Postgresql gets stuck even updating the post index:
query | UPDATE post_search_data        +
      | SET        +
      |    raw_data = 'La copia de seguridad se completo exitosamente The backup was successful. Visit the //community.coopdevs.org/admin/backups community coopdevs org admin backups admin > backup section to download your new backup. Here
<E2><80><99>s the log: [2016-09-30 03:39:37] [STARTED] [2016-09-30 03:39:37] ''system'' has started the backup! [2016-09-30 03:39:37] Marking backup as running... [2016-09-30 03:39:37] Making sure ''/var/www/discourse/tmp/backups/default/2016-09-30-033937'' exists... [2016-09-30 03:39:37] Making sure ''/var/www/discour:
The fun fact is that I deleted the topic with that information and restarted the app (that triggers an index re-build) and it gets stuck again at UPDATE… for another topic related to backup… different date but similar content.
It seems that those topics contains something that the same Postgresql doesn’t like to parse again… :face_with_head_bandage:
