Keyboard Shortcut menu throwing scroll bar (again)
keyboard
(TechnoBear) #1
The bottom two items in the left-hand column are not visible until you scroll down - which can only be done with a mouse…
Given the width of the box, the content could easily be displayed in three shorter columns.
I know this was fixed once before, but I think the contents have since expanded.
Options to disable hijack of CMD+F / CTRL+F and "/" keys for search?
(Jeff Atwood) #2
Good point and easy change – I just made it 3 columns as suggested. Hope that helps.
(Jeff Atwood) #3
