Large cookie breaks site
I have an install where the forum is on a subdomain of the main web site, so they’re sharing the same primary domain. I set a cookie on the main web site that is on the large side. If I then try and go to the forum site in Edge (works in Chrome, Firefox, etc.) it breaks and says it can’t reach that page. If I delete the cookie, the site loads fine. I need the cookie to be on the root domain as it’s shared among other sub-domains but it’s not actually used on the forums. I tried adjust nginx settings to allow large headers, but that hasn’t made a difference. Any idea what I need to do here (other than not use edge and/or use a smaller cookie)?
Example:
On www.example.com, set cookie MyBigCookie=3+k value using domain = .example.com.
Go to forums.example.com in Edge - site is unreachable.
Doesn’t the nginx have maximum default cookie sizes? You might need to change that in the nginx config in the Discourse container.
Already tried those. Unfortunately it didn’t make a difference.
I was able to adjust my cookie size to work around it for now.
