Launcher not responding
docker
(Josh M) #1
Since the upgrade to v1.4.0.beta4 +51, launcher hasn’t been responding. No errors, nothing, just kicks me back. Has something changed?
(Josh M) #2
Tried updating…
root@host [1266 11:17:12 /var/docker]# yum -y upgrade docker-io
Loaded plugins: changelog, downloadonly, fastestmirror, security
Setting up Upgrade Process
Loading mirror speeds from cached hostfile
Still…
root@host [1268 11:19:19 /var/docker]# ./launcher rebuild app
root@host [1269 11:19:27 /var/docker]#
with…
root@host [1269 11:19:27 /var/docker]# docker info
Containers: 15
Images: 35
Storage Driver: devicemapper
Pool Name: docker-8:6-2101608-pool
Pool Blocksize: 65.54 kB
Backing Filesystem: extfs
Data file: /dev/loop0
Metadata file: /dev/loop1
Data Space Used: 6.114 GB
Data Space Total: 107.4 GB
Metadata Space Used: 6.681 MB
Metadata Space Total: 2.147 GB
Udev Sync Supported: true
Data loop file: /var/lib/docker/devicemapper/devicemapper/data
Metadata loop file: /var/lib/docker/devicemapper/devicemapper/metadata
Library Version: 1.02.89-RHEL6 (2014-09-01)
Execution Driver: native-0.2
Kernel Version: 2.6.32-504.23.4.el6.x86_64
Operating System:
CPUs: 8
Total Memory: 7.785 GiB
(Jeff Atwood) #3
This is a world of hurt. Nothing will work reliably for you as devicemapper is beyond buggy. You need to get aufs going.
