# Layout Issue in Mint Theme on Mobile: Topic List Container Not Full Width
**URL:** https://meta.discourse.org/t/layout-issue-in-mint-theme-on-mobile-topic-list-container-not-full-width/387241
**Category:** Bug
**Tags:** mobile, mint-theme, ux
**Created:** [October 31, 2025, 10:44am UTC](https://meta.discourse.org/t/layout-issue-in-mint-theme-on-mobile-topic-list-container-not-full-width/387241 "2025-10-31T10:44:36Z")
**Posts on this page:** 1
**Page:** 1
<div class="post-metadata">
### Author: ![serkhelesheyi](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/serkhelesheyi/32/497726_2.png) [@serkhelesheyi](https://meta.discourse.org/u/serkhelesheyi)
#### Post date: [October 31, 2025, 10:44am UTC](https://meta.discourse.org/t/layout-issue-in-mint-theme-on-mobile-topic-list-container-not-full-width/387241/1 "2025-10-31T10:44:36Z")
</div>
Hello,
I’m currently using the Mint Theme on my Discourse forum and have encountered a layout issue that only appears in mobile view.
Problem Description:
On the latest page, the topic list container does not span the full width of the screen. Instead, it appears boxed with noticeable empty space on both the left and right sides, which disrupts the visual balance and reduces usable screen area. This issue is not present in desktop view, where the layout behaves as expected.
Environment Details:
- Theme: Mint Theme (latest version)
- Platform: Mobile only (tested across multiple browsers)
- Plugins: No layout-affecting plugins installed
- Custom CSS: None applied
- Discourse & Theme Version: Fully up to date
Screenshot:
Below is a screenshot showing the issue. You can clearly see the unused space flanking the topic list container:
 ![!Mobile layout issue: boxed topic list with empty margins](https://global.discourse-cdn.com/meta/original/4X/9/7/b/97b936761a66071eba986df4f2b4505b81103727.jpeg)
Request:
Could you please advise whether this behavior is intentional in the Mint Theme’s mobile layout, or if it can be adjusted via theme settings or CSS override? Ideally, the topic list should utilize the full screen width on mobile for better readability and user experience.
Thank you in advance for your guidance!
