Is there a setting that will allow us to revert to the previous layout of the display of topics i.e. a single line, By that I mean such that the category is not displayed under the topic title but in the same line as it used to be.
Perhaps you should look at this topic:
This component does what you want, if I understand correctly.
Thanks, I will follow this up.
Just to add that this has been successfully implemented - many of our group members did not like the change because it limited the number of topics visible in one screen reducing that by 50%. Some with limited visibility or reduced mobility found it difficult to select the topic rather than the category.
It would be useful if the developer team always created a “maintain/revert to previous” option or settings before making a major layout change.
Is there something I can add to this theme to make avatars square. You have no idea how our people dislike round.
You can just override the css. Currently:
img.avatar {
border-radius: 50%;
Is rounding the corners. Change it to:
img.avatar {
border-radius: unset;
Great thanks, implemented and sorted.
I am an old mainframe man from cobol and fortran days so I struggle a bit to keep apace of the current technology.
Is unset
the correct syntax here? I typically put 0
there.
Hm you might be right, I relied on the chrome inspector autocomplete. This wouldn’t be the first time it was my undoing.
