LDAP login into Discourse
(Chanka Dod) #21
This works like a charm. Thanks
(Alagappan Vairavan) #22
I installed jonmbake/discourse-ldap-auth plugin. The ldap auth plugin shows up in the discourse login page. After successful ldap user auth, instead of logging in to the homepage it redirects to new user registration page. I already configured ‘auto’ for ldap_user_create_mode in plugin settings. Is there a way to sink all users from ldap? I also unchecked ‘Public registration disabled’ under login settings. Anything I am missing on plugin config?
I am on discourse 2.1.0
OpenLDAP: slapd 2.4.40
rails log sample :
Started GET "/auth/ldap" for 127.0.0.1 at 2018-06-12 23:44:07 +0000
(ldap) Setup endpoint detected, running now.
(ldap) Request phase initiated.
Started POST "/auth/ldap/callback" for 127.0.0.1 at 2018-06-12 23:44:15 +0000
(ldap) Callback phase initiated.
Processing by Users::OmniauthCallbacksController#complete as HTML
Parameters: {"username"=>"andy", "password"=>"[FILTERED]", "provider"=>"ldap"}
Rendering users/omniauth_callbacks/complete.html.erb within layouts/no_ember
Rendered users/omniauth_callbacks/complete.html.erb within layouts/no_ember (1.6ms)
Rendered layouts/_head.html.erb (0.5ms)
Rendered common/_special_font_face.html.erb (0.3ms)
Rendered common/_discourse_stylesheet.html.erb (0.2ms)
Rendered application/_header.html.erb (0.2ms)
Completed 200 OK in 10ms (Views: 4.3ms | ActiveRecord: 0.6ms)
Started GET "/u/hp.json?_=1528847052831" for 127.0.0.1 at 2018-06-12 23:44:15 +0000
Processing by UsersController#get_honeypot_value as JSON
Parameters: {"_"=>"1528847052831"}
Completed 200 OK in 2ms (Views: 0.3ms | ActiveRecord: 0.0ms)
Thanks,
Al
(John Lock) #23
Hello, it seems I’m facing a similar issue, user can sign-up the first time and get logged-in, if I try to log out and log-in again, it gets to the registration page but can’t continue because user already exist.
If you found something to fix this, that’d be great.
