# Let's Encrypt SSL certificate not renewing automatically 2nd time consecutively
**URL:** https://meta.discourse.org/t/lets-encrypt-ssl-certificate-not-renewing-automatically-2nd-time-consecutively/394304
**Category:** Support
**Tags:** letsencrypt
**Created:** [January 25, 2026, 11:22pm UTC](https://meta.discourse.org/t/lets-encrypt-ssl-certificate-not-renewing-automatically-2nd-time-consecutively/394304 "2026-01-25T23:22:11Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![jbrains](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/jbrains/32/208183_2.png) [@jbrains](https://meta.discourse.org/u/jbrains)
#### Post date: [January 25, 2026, 11:22pm UTC](https://meta.discourse.org/t/lets-encrypt-ssl-certificate-not-renewing-automatically-2nd-time-consecutively/394304/1 "2026-01-25T23:22:11Z")
</div>
Hi, folks. I need some help troubleshooting. For the second straight time, my Let’s Encrypt SSL certificate did not renew automatically. In reading the relevant threads here, I managed each time to renew the certificate by removing the old one and rebuilding the app. I was under the impression that doing this would cause the renewal to happen automatically next time. It did not.
I don’t see any evidence of a `cron` job running anywhere that tries to renew the certificate. I presume I ought to look in the various places on the host machine, as opposed to inside the Docker container. Do I have that right? `crontab -l` says “no crontab for root” and I see nothing in `/etc/cron*`.
As a result, I can’t feel confident whether my server is (1) not attempting to renew the certificate or (2) attempting and failing. Is someone willing to guide me through troubleshooting this?
Unfortunately, since I nuked `shared/standalone/{letsencrypt,ssl}` in order to provision the certificate anew, I don’t have old logs to look through. How would I at least verify that the `cron` job is installed so that I can check the logs the next time the system attempts to renew the certificate?
Thanks.
### Author: ![Moin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/moin/32/554653_2.png) [@Moin](https://meta.discourse.org/u/Moin)
#### Post date: [January 26, 2026, 10:04am UTC](https://meta.discourse.org/t/lets-encrypt-ssl-certificate-not-renewing-automatically-2nd-time-consecutively/394304/2 "2026-01-26T10:04:32Z")
</div>
I think it cozld be the last time this happened. There was a fix in December:
> [@Discourse failure to renew certificate](https://meta.discourse.org/t/discourse-failure-to-renew-certificate/385148):
> Continuing the conversation from here: I got a reminder from Redsift that my certificates are going to expire in a week. Usually discourse will renew the certificates well ahead of time. This time not so, before I start doing a rebuild (which is supposed to solve the issue), @Falco is there anything you want me to check and post back here to help get to the root of why the certificates did not renew? The root certificate is ISRGX1 and here is the expiring certificate information: Common…
#### Post date: [January 26, 2026, 3:09pm UTC](https://meta.discourse.org/t/lets-encrypt-ssl-certificate-not-renewing-automatically-2nd-time-consecutively/394304/3 "2026-01-26T15:09:50Z")
</div>
Danke sehr, but I would very much prefer to check the settings to see whether the upcoming renewal is likely to happen. I don’t know how to check those settings, so that is the help I’m asking for now.
Apparently, there should be a cron job. Where is it? I don’t see one listed on my server. Is this not really a cron job, but a scheduled task in Rails?
I saw in `/var/discourse/shared/standalone/letsencrypt/acme.sh.log` (on the host system) that Discourse checked my SSL certificate and the response was “It’s still valid”, so I suppose that’s evidence that Discourse will attempt to renew the certificate in time.
Now I would like to know how that “cron” job is configured? Is this truly a Linux-level `cron` job or merely a recurring scheduled task in Rails using something like `whenever`? Is this something I can examine and check without looking through source code? Could I find this using the Rails console or whatever that is in 2026? (I haven’t worked in Rails in a long time.)
Thanks.
#### Post date: [January 26, 2026, 4:24pm UTC](https://meta.discourse.org/t/lets-encrypt-ssl-certificate-not-renewing-automatically-2nd-time-consecutively/394304/4 "2026-01-26T16:24:53Z")
</div>
Oh and hey, I have finally learned that this defect came down to an undocumented, not-very-clear, evidently unexpected, magic shortcut. “If it starts with `/`, then it _must_ be a regex.” I don’t understand the entire context yet, but that’s what it seems to be.
That’s Duck Typing culture for you: wonderful flexibility with the risk that if you don’t write things down, clients are in for a surprise. 😉
It seems like it would be wise to strengthen `Pups::ReplaceCommand` to check more carefully for whether `to` looks like a regex or not. Or whatever it’s doing that assumes that it should `eval()` something instead of treating it as the replacement text.
I presume this falls under the category of Janitorial Work That Nobody Has Time Nor Energy To Do? If someone could point me to some helpful examples of how `ReplaceCommand` needs to behave, maybe I could donate some time and energy to it.
At least I have a better idea what’s going on, but that knowledge has already started decaying even before I finished writing this sentence. 🤷
