Limit categories appearing in main categories view
#1
I’m working on a project in in which there will be a ton of categories, but I only want categories that users follow to show up in categories/latest view for them, while maintaining the ability of the users to view those categories when linked directly.
ie. User gets cat 1 and cat 2 in their latest/categories, but can only see cat 3 if they follow a direct link. User 2 sees cat 2, but can only see cat 1 and cat 3 if they follow a direct link. etc
The way I see it, I need to either modify the existing subscribe ability, or add a new one, and then modify the categories/latest
Just looking for general advice for the best approach to this problem via a plugin or dirty hacky antics before I dive in.
Thanks friends
(cpradio) #2
I think this is on the roadmap already for 1.4, it technically exists as you can use latest-cat1 in your navigation site setting, but they wanted to make it more user friendly.
has
Move suppress category from homepage into category settings
#3
True, but this I think only removes the posts from the latest category, not from the discourse.example.com/categories view right? Or is the future feature planning on tackling both realms?
(cpradio) #4
Oh, that is true, so this would be one step further.
Have you thought about using tabs instead of those extra categories that you don’t want visible?
(cpradio) #5
Sweet! You can do this in CSS, I just did the following using Google Dev Tools here on Meta to hide the Features category from view
tr[data-category_id="2"] { display: none; }
Replace “2” with the category_id you wish to hide
#6
Ok that is a really simple solution, and I can just conditionally load the css based on the user. I’m so glad I asked here.
Now all I have to do is worry about the Latest category (per user)
Thank you!
