Link dialog New Topic does not always include context
(Dave McClure) #1
When I click + New Topic the composer is blank. Shouldn’t it be filled in with the link or something?
With the new right gutter, where should "Reply as Linked Topic" go?
(cpradio) #2
Which one are you clicking on? As the topic one is indeed blank, the post one isn’t. The +New Topic requires a post context, which makes the link on the topic more difficult.
(cpradio) #3
Oh wait… @zogstrip, something weird is going on, as when I use @mcwumbly’s post above, it is blank, but if I use @codinghorror’s post, it fills out properly.
Edit:
Strike that, repo is last 2 posts fails to insert link, all other posts work fine.
(Jeff Atwood) #4
Works for me, are you guys doing it on posts that arrived after you opened the topic or something?
(Mittineague) #5
I just tried on a different topic. The later 11 posts or so don’t populate with the reference to the source post.
The last post that does is
(Tom Wrench) #6
I’m getting similar inconsistent results. Using this thread, if I click ‘share’ -> ‘reply as linked topic’, the composer fills out the linked topic for posts 91 and above, but the most recent posts 92 & 93 are resulting in a blank composer.
(Jeff Atwood) #7
Can you repro this @zogstrip?
(cpradio) #8
I can still repo on meta using the original topic this was split from
(Régis Hanol) #9
Thanks for the repro @cpradio & @Mittineague :thumbsup:
(Jeff Atwood) #10
(Erlend Sogge Heggen) #11
I’m still not getting context on Meta nor Try.
(Sam Saffron) #12
Seems to be working for me, perhaps reopen with an exact repro?
(Régis Hanol) #13
I actually can reproduce. Will fix…
(Régis Hanol) #15
It’s now fixed :pizza:
(Jeff Atwood) #16
