Link directly to latest post?
(To The Tick Llc) #1
Is their a URL extension that can best used to send users straight to the latest post?
for example something like…
http://discuss.financialjuice.com/t/ichimoku-kinko-hyo-and-measured-moves-in-the-es/183/latest
DC is so incredibly powerful that we can actually use it for a real time chat room on our site…need a smart way to link to it from the from page of our site so that the user is taken straight to the latest post.
Ideas welcome
(Régis Hanol) #2
Kind of a hack, but you could link to: http://discuss.financialjuice.com/t/ichimoku-kinko-hyo-and-measured-moves-in-the-es/183/9999999
(To The Tick Llc) #3
That doesn’t seem to work for me, it just takes me to the post that I last read on that page (not the very latest one.
(To The Tick Llc) #4
@zogstrip try clicking the link you sent what URL does it take you to?
I had someone that has never used the site do it…and it took took them to the same page as it did me.
(Neil Lalonde) #5
@tothetick Your site is running an old version of Discourse, from about 2 months ago. I tried @zogstrip’s trick on a topic I haven’t read on meta, and it worked. So you should probably upgrade.
(To The Tick Llc) #6
Cheers @Neil will investigate
(Jeff Atwood) #7
We should probably create a named alias for this @neil and @zogstrip.
Seems like
http://discuss.example.com/t/topic-title/183/last
is preferable to the hack
http://discuss.example.com/t/topic-title/183/9999999
Latest links from the homepage should not use this “last” form since they will not show the correct browser visited link color as a numbered link would. So this ends up being kind of a specialized function, but I don’t see any downside other than obscurity.
(Jeff Atwood) #8
This is now implemented.
(To The Tick Llc) #9
Just add last to the URL ?
(Jeff Atwood) #10
It’s linked from the topic lists as well, if the last post is the correct entry point.
(Jeff Atwood) #11
