Linking topics without quoting and link points to ip address instead of hostname
(Immigrationloop) #1
Hello,
Pl pardon my ignorance as am still getting up to speed on discourse, and we absolutely love discourse for our forum. I manage the community over at www.immigrationloop.com.
I wanted to get help on two questions/ issues:
  1. Is it possible to link related topics to each other without having to quote one topic in the other? I tried reply as linked topic, but don’t want to quote the related topic/post in the new post.
I also tried doing, but this leaves a blank grey horizontal bar
[quote=", post:1, topic:243, full:true"] [/quote]
like the one below:
How do I link multiple topics to a topic (after they’ve been created)?. Any help is appreciated.
  1. When I reply as a linked topic and quote the initial topic, I see the linked topic. However, clicking on it opens the related topic with the IP address of my host (http://xxx.xxx.xx.xxx/) instead of the domain name (www.immigrationloop.com). I confirmed that app.yml has the domain name as immigrationloop.com? how do I fix this?
Thanks again!!
Admin @ immigrationloop.com
(Jeff Atwood) #2
Simply place a hyperlink between the two topics in any reply and they will be linked. Quotes are not needed, URLs and links are.
Sounds like you have a bad configuration. Did you have the IP address as the name of the site in app.yml? If you changed that, did you rebuild the container?
(Immigrationloop) #3
Thanks @codinghorror.
  • the linking works great by just placing the url of the related topic in any reply.
  • Yes, I set the initial app.yml DISCOURSE_HOSTNAME param to IP address and recently changed it to domain name and ran ./laucher rebuild app inside /var/discourse. The issue is now resolved.
You rock!!
(Daniel Hollas) #4
Ok, maybe I do not understand what is really meant by linked topics. I would like the links to the linked topics displayed right below the first post, just like what automatically happens when replying via new topics. What I want is e.g. this:
When I simply placed the hyperlink in the reply, it was not added to this section.
(Jeff Atwood) #5
That is what it will look like on the receiving end. On the sending end, it will look like a plain regular link in the body.
(Daniel Hollas) #6
Thanks for quick reply! :heart: In that case, I would like to report a bug or my own stupidity. :slight_smile:
On our forum instance, this does not appear to work i.e. when I mention a topic in a post, the link to the topic of that post does not appear in the mentioned topic (if I got your logic right :slight_smile: ) Are there any possible reasons for that? Do I need to enable it in the settings somewhere?
(Daniel Hollas) #7
Ok, did a quick test. It appears that one has to provide a full link i.e. https://example.com/t/name_of_topic/topic_id
What I was originally doing is https://example.com/t/topic_id
This redirects to the full URL but does not link the topics, so it looks to me as a bug rather than a feature.
By the way, relative URLs also work, e.g. /t/topic_name/topic_id
EDIT: This also seems to work: /t/topic/topic_id where topic is not a variable in this case.
(Jeff Atwood) #8
This is not remotely in any way correct. You need a slug in there. Redirection is a “fix your broken link for you” feature. Try
https://example.com/t/LITERALLY-ANYTHING-HERE/topic_id
Let’s see.
https://meta.discourse.org/t/x/71741
Yep works fine:
