Load balancing for Discourse
(Ilya Kuchaev) #1
Is there any how-to for the balanced environments?
(blaumeer) #2
Have you tried searching for “load balancer” in the top right search box? It yields several interesting results on the topic :smile:
(Ilya Kuchaev) #3
Sure. There is no any topic with the How-To’s only partial details :frowning:
(Sam Saffron) #4
How is load balancing Discourse different to load balancing any other web application on Linux.
You run web containers on multiple machined and haproxy or varnish in front.
Using the docker container ./launcher script how would I rebuild the web_only container before taking the old one offline?
(Khoa Nguyen) #5
Can you write a post about this? I want to settup load balancing for my discourse
(Benoit Chesneau) #6
the main question is how you replicate the data? any other way than using drbd ?
