Loading error often occurs
During about 6 months, this error message often shows up.
When this is shown, I have to wait at least 30 seconds to click any buttons.
The situation seems getting worse.
My discourse version is the latest one, 2.4.0.beta9.
I would appreciate it if someone could tell me how to solve this.
error
Can you see any errors in the console? I find this is usually a result of Discourse throttling you, for example when opening multiple pages in tabs. It could also happen if you work with a proxy (or Cloudflare), and have not set up IP forwarding properly. In that case, all traffic will appear to originate from the same IP, which will then get throttled.
