Loading Test Data, and reloading it
(cpradio) #1
Okay, so I’ve generated my own test data up to this point, but it is becoming increasingly difficult to ensure I test all scenarios against my own data.
Is there data we can load into our development environments? I don’t have specific situations in mind, but it just seems it would be easier to development changes against an existing dataset than manually creating a bunch of topics/posts.
Also is there an easy way to unload the existing dataset and reload it with the default data (in case I alter the data in some way so I can get it back to its default state?)
Thanks.
(lid) #2
First thing come to mind is that you can use the backup/restore mechanism.
which should provide you with the must complete solution data wise.
