Local development with Docker?
(Zach Alexander) #1
I’d like to set up Docker locally (on OS X) to run development versions of my forums.
I’ve installed Docker, but I don’t really know where to go from here. Should I clone the Discourse docker image into /var/docker on my Mac, or create an Ubuntu VM first and do it there?
(Sam Saffron) #2
I plan to shift all my dev work into a docker container, but have not gotten around to it.
Once I have that done I will publish it so the rest of the community can enjoy it.
Setting up a dev image is quite involved. You could start with our base image but you would need a pile of extra stuff.
#3
That would be very nice…Thanks in advance.
(Zach Alexander) #4
I thought the whole point of Docker is that it packages the entire environment you need – curious what the pile of extra stuff is.
In the meantime, seems like it might be easiest for me to create a (remote) staging server and use that for development.
(Sam Saffron) #5
phantomjs, my vim config would be the 2 big ones off the cuff.
