Localhost CreateQueuedPosts error
(Mittineague) #1
I sync’d my localhost install of Master the other day but can’t figure out what’s wrong or how to fix it
CLI shows
[vagrant@precise32:/vagrant (master)]$ bundle exec rake db:migrate
== 20150325190959 CreateQueuedPosts: migrating ================================
-- create_table(:queued_posts, {:force=>true})
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::UndefinedObject: ERROR:  type "json" does not exist
LINE 1: ...ger NOT NULL, "raw" text NOT NULL, "post_options" json NOT N...
: CREATE TABLE "queued_posts" ("id" serial primary key, "queue" character
varying(255) NOT NULL, "state" integer NOT NULL, "user_id" integer NOT NULL, "raw"
text NOT NULL, "post_options" json NOT NULL, "topic_id" integer, "approved_by_id"
integer, "approved_at" timestamp, "rejected_by_id" integer, "rejected_at"
timestamp, "created_at" timestamp, "updated_at" timestamp)
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rack-mini-profiler-0.9.3/lib/patches/db/pg.rb:90:in `exec'
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/rack-mini-profiler-0.9.3/lib/patches/db/pg.rb:90:in `async_exec'
/usr/local/rvm/gems/ruby-2.0.0-p0-turbo/gems/activerecord-4.1.9/lib/active_record/connection_adapters/postgresql/database_statements.rb:128:in `block in execute'
if I start the server anyway the browser shows
ActiveRecord::PendingMigrationError
Migrations are pending. To resolve this issue, run: bin/rake db:migrate RAILS_ENV=development
Extracted source (around line #10):
8     end
9
10    call_without_quiet_assets(env).tap do
11      Rails.logger.level = previous_level
12    end
13   end
Rails.root: /vagrant
Application Trace | Framework Trace | Full Trace
config/initializers/quiet_logger.rb:10:in `call_with_quiet_assets'
config/initializers/silence_logger.rb:26:in `call'
lib/middleware/missing_avatars.rb:21:in `call'
lib/middleware/turbo_dev.rb:33:in `call'
* trying RAILS_ENV=development did not fix things
Ideas please
(Robin Ward) #2
Check your version of postgres. Json might be in a later release.
(Mittineague) #3
My Postgres was from 14 months ago.
I updated it, restarted my computer and tried again.
Still no joy, but I’m sure I missed doing something along the way.
The good news is that when I switched from master to beta and tried - It’s Alive !!!
I can live with that, as long as I can work on plugins I’m a happy camper.
(Sam Saffron) #4
json data type is only supported on PG 9.3 and up.
@eviltrout we should probably update dev docs to mention 9.3 and up is required.
#5
Yeah I’m getting this in the vagrant environment as well. Is this not the supported dev environment anymore?
(Robin Ward) #6
It sounds like our vagrant image needs to be updated. It has been a long time!
(Simon Cossar) #7
When I enter psql into the terminal using the current vagrant image, this is what I get.
[vagrant@precise32:/vagrant (try-things-out)]$ psql
psql (9.1.8)
Type "help" for help.
vagrant=#*
Is that the relevant postgres, or is it the one on my host machine that matters?
#8
The postgres version within their Vagrant image needs to be updated, thats all. I can confirm the workaround above is working however (switching to beta as opposed to master)
#9
Another thing to keep in mind is that mailcatcher isn’t installed.
(Robin Ward) #10
I’ve updated our vagrant VM to support the latest postgres and ruby. It should be faster and cleaner to use too:
https://github.com/discourse/discourse/commit/17dc8b8e4f2bf7b984ae279f7a0f76a810ac8dd8
(Jeff Atwood) #11
Are any changes to the related blog entry needed?
(Robin Ward) #12
I forgot about that! I used the latest version of vagrant so if you update the blog to say to install 1.7.2 or later that would be good. Everything else looks fine.
(Jeff Atwood) #13
Ok I updated the blog post to reflect current versions… @techapj will run through it as well to see if all is good.
(Arpit Jalan) #14
I just installed Discourse as my first Rails app on Windows! :blush:
Here’s the screenshot of Discourse running on my Surface Pro 2:
So I can confirm everything is good! Thanks for the update @eviltrout!
(Jens Maier) #15
Wow, for a second there I thought Discourse was now actually running natively on Win32… :unamused:
