Locked out after update
hi all,
unfortunately the recent change of the HTTP method for the token url (/oauth/token) from POST to GET just locked me out after the update :slightly_frowning_face: I had to use the rails console in my instance to generate the SiteSetting manually to fix it. I must be able to run the forum with OAuth login only.
I use a rails app with doorkeeper as the authorization server. It unfortunately does not offer a GET route for /oauth/token.
Would it make sense to stick to POST as the default method?
Not sure, if itโ€™s violating the OAuth specification though.
This has been put back to the default after we got some error reports. We had no desire to change the default. It was done accidentally.
:smiley: :+1: Thanks a lot!
That was on me, sorry about that.
On a different subject, Iโ€™m running into another use case for this plugin, I need to ping the user json user url in arbitrary before_action's, which means that I need to keep the unhashed access token in memory.
Iโ€™m thinking about setting it in session[:oauth2_access_token] within after_authenticate, and offer the class method OAuth2BasicAuthenticator.get_bearer_token.
Is that the right place to do something like this? Are there any concerns about keeping the access_token in session?
