Log out does not work
Hi,
I have the issue wherein when clicking the “Log Out” button within my discourse instance, it will redirect me to /login and show me the “You have been logged out”-modal, which will not go away unless I clear my caches. What should I do to fix this?
Kind regards
Please check if the site setting logout redirect is empty or not. If not, delete the redirect URL inside. If it is empty can you try to see if this issue happens even in safe-mode disabling themes and all the third party plugins?
Tried both things you suggested, neither worked.
