Logging in to Admin when email-based login is disabled
(Quincy Larson) #1
I wanted to force all our community’s users to use Github auth instead of allowing for email-based signup. After configuring this, impersonated a user. Once I signed out, I was unable to get back into the admin account.
What’s the best way to regain admin access?
(Khoa Nguyen) #2
You can edit your app.yml file and add your main github email there.
Rebuild your app and login with github
(Kane York) #3
Follow this topic to the “rails console” step, and do this:
> SiteSetting.enable_local_logins = true
> exit
$ exit
# exit
(Quincy Larson) #4
@riking and @thangngoc89
That did the trick! If anyone reading this is using the BitNami instance, here’s a working command to pull up the rails console:
/opt/bitnami/apps/discourse/htdocs/bin/rails c production
Then: SiteSetting.enable_local_logins = true
