Login failure after upgrade
(Johnny D) #1
I experience login failure after upgrade, and I need your feedback to fix this.
https://www.pix.as/ In order to have my website working, I have restored to the previous version - and I’ll attempt to perform upgrades once the error has been located.
My current version is v1.7.0-beta1+28, and I would like to upgrade to beta8.
Once I perform the upgrade, post/update/login/logout functions stop working - and I also have problems login with socials.
Anyone aware of any updates or changes, I need to make before upgrade?
(Jeff Atwood) #2
Do you have incompatible plugins? Have you tried safe mode?
(Rafael dos Santos Silva) #3
Are you using a simple docker install or do you have a reverse proxy (like nginx) outside docker? Are you using https?
(Johnny D) #4
No, I have not tried safe-mode as I’ve disabled all plugins during troubleshooting, and the problem persists.
I am thinking about https setup, as the website/webserver is using http, where all traffic is forced https via AWS CloudFront.
  • This has been working perfect for 6+ months.
So, still wondering about the root cause here?
(Jeff Atwood) #5
If you have a reverse proxy you need to explicitly send the HTTPS header in.
